Throttled 37 Posted February 24, 2014 Share Posted February 24, 2014 Bought from eBay for about £4.http://i.ebayimg.com/00/$(KGrHqIOKpUE3tk)2uq+BOEGWHlK5!~~_35.JPG?set_id=8800005007A simple tube with a non return valve. Undo the bleed nipple, push on the pipe and then as you pour in the brake fluid to the reservoir pump the brake lever. I have the other end into a plastic jug. The excess fluid can go back into the bottle as all it has done is get pumped through the pipe. It is so easy for one person to do and I did a brake in a couple of minutes. Just pump till the fluid has no bubbles in it, which if you keep the reservoir topped up is very quick. Brilliant little tool and I find it easier than mucking about trying to use a vacuum pump system to pull the fluid through. Quote Link to post Share on other sites
Zipster 0 Posted February 25, 2014 Share Posted February 25, 2014 Good job. I have one of the draper kits but the non return isn't up to much!! I may splash out and treat myself to one of these. Quote Link to post Share on other sites
Stu 678 Posted February 25, 2014 Share Posted February 25, 2014 I have one of these! I dont rate it at all!! Quote Link to post Share on other sites
Joeman 0 Posted February 25, 2014 Share Posted February 25, 2014 whats wrong with keeping the end of the pipe submerged in a jamjar full of fluid? Quote Link to post Share on other sites
Mr Fro 52 Posted February 25, 2014 Share Posted February 25, 2014 whats wrong with keeping the end of the pipe submerged in a jamjar full of fluid?Because sooner or later it'll go *ping!* out of the jar and splash paint death fluid all up your fairing! That's why I stuff a load of paper towel in the jar to get the pipe wedged in nice and tight. Quote Link to post Share on other sites
