Takanta Posted November 18, 2009 Posted November 18, 2009 anywhoo , I bought bike a few weeks back and i still aint had the chance to rid it , bit crappy since its my first ever bike haha the bike is desperately needing both tyres changed, I can't ride the bike to a garage since its not insured and too dangerous with the amount of tread left.aaaaand all the garages ive called will only change the tyres if i take the wheels off the bike. (they wont take the bike in)I have the new tyres sitting here , but im running out of funds so is there any way at all to remove the back and front wheels of the bike without having to splash out for paddock stands? Quote
Guest Posted November 18, 2009 Posted November 18, 2009 (edited) yes.. depends what you have to hand... car axle stands..? centre stand..?with a centre stand the rear wheel can be removed, get it changed and back on, then using a car jack lift the front, support on axle stands and remove the front.. save up some funds and get a front and rear, the shops tend to do deals this time of year,bike doesnt have a centre stand? then you need someway to lift the rear whilst supporting the bike. engine hoist crane? garage with strong spans (pref Steel).. strop it and lift it, might want someone to help you here.. do rear, then do front.best bet, see if someone near you will help or has stands...paddock stands cost £30+ and do you really want to see your bike lying on the floor... a wise investment... Edited November 18, 2009 by Anonymous Quote
Colin the Bear Posted November 18, 2009 Posted November 18, 2009 otherwise lie bike down on an old mattress, Don't do thisYou'll lose oil, fuel and battery acid. A right mess.The Hyosung 125 isn't a big bike. Get some one to help and pop it up on some wood blocks. Quote
Guest Posted November 18, 2009 Posted November 18, 2009 when needs must, it has been done... and i was hoping to shock as paddock stands arent expensive and a good shed investment, and far safer than all of the alternatives.. Quote
Colin the Bear Posted November 18, 2009 Posted November 18, 2009 Look what I foundhttp://www.motorbike-search-engine-shop ... Lifts.htmlhttp://www.amazon.co.uk/1500LB-HYDRAULI ... 812&sr=8-4 Quote
Guest Posted November 19, 2009 Posted November 19, 2009 most young un s with 125's dont have a lot of money. You can loosen the back wheel right off then a couple of you can lift the back end before chocking the swing arm up with solid pieces of wood. Then remove the wheel completely. It sounds like a chew on but its a ten minute job. Quote
Takanta Posted November 19, 2009 Author Posted November 19, 2009 Thanks for the help folks, yea I dnt have a lot of money lol i've already nearly maxed out my student overdraft hahahha, anyway thanks for the links colin , I'll be keepin an eye on that amazon link. Quote
