Downpipe change tomorow
JoshTimmins
Just before i start, anything worthy to look out for, will i need to change anything because of the new pipes, etc. :)
Just so i dnt get to something and think ARGGHH f*ck it! lol :P
Ta
Josh
oh and haynes is at the ready, and says:
-remove bellypan
-drain coolant
-remove rad
-undo and take off downpipes, and silencers off if i need to.
-do reverse with installtion of new gaskets, clamps, etc :)
Depends what the bike is, but I'd take off the exhaust cans before dropping the downpipes. It'll just make it easier to maneuver the downpipes out.
Also, again depending on the bike you might not have to drain the coolant and take the radiator off. In my Haynes for the Blackbird it says to take the radiator off, but I found if I just took my time and displaced the radiator it was all OK. You just need to be careful you don't drop the downpipes onto the radiator because it's fragile.
You'll be OK Josh, just keep refering to Haynes to make sure you're on the right track. Once you've done it you'll think it's simple :thumb:
you'll need a pair of gaskets (engine to header), and be careful when undoing the bolts/nuts/studs, if they break it makes a bigger job, if you can spray with penerating spray and leave overnight, might help if you warm things up before you start (might want to wear gloves)
gaskets come with downpipes :D yipee!
and will bare that in mind ta :)
Josh
lets hope all goes well
When I took my exhaust in for repair the welder was going on about shearing exhaust studs off with the engine cold and you should warm the engine up first. That strikes me as odd to be honest, but thought I'd mention it (if Haynes doesn't tell you to then don't).
Good point Frankie made about gaskets but glad you've got some. I put some gasket sealer in there as well when I do it but you'll be fine without that no doubt.
Good luck with it, let us know how it goes.
adter abit of bodging, its done.
old exhaust is in aright state, on one of the downpipes, about 2inch from silecer, ther was such a crack dad just ripped the silencer off lmao!
Holes everywhere, much needed me thinks.
Bike wont start lol battery just dead, that cant be done til tomorow soo still no bike :( :( and am pretty pissed off lol! means another Train journery, oh well downpipes look sweeeeeeeeet!
Josh
right, was ok for a day, but we had to bodge a seal..
bike shop said to use exhaust bandage and clamp down, so we did... exhaust bandage has now discintegrated(sp?) soo now the only thing we can think off and doing is:
Making some tubing, cut a slot in it, use it as a seal, then clamp tht down :) thats not gnna burn away :D
trouble is i need bike for wed(to see the GF) and deffo by Thurs(working down in london and need to get there :/) lmao! gtaa hurry :)
Josh
Didn't you buy some Delkevics, Josh? Or was that someone else?
What's with all the bodged repairs? I feel like I've missed something again :( lol! Have you just taken the old pipes off and put them back on again after repairing them?
Oh and what're you going to make the new pipe tube thing out off...not drainpipe I hope :lol:
right :P i hadnt posted bout it lol soo here goes!
The old pipes, the silencer seal to the downpipes on one of the pipes (old ones) was bodged with wirewool and some putty sorta looking stuff. Then clamped on, ofcourse we didnt see this til after takign the silencer off.
So went to halfords to see what the got, on the way went into mechanics to see what they recommended, they werent in :/ lol but there is a bike shop 1min away, so popped in there, and they said to use exhaust bandage. Sooo thats what we did, uesd the bandage, made a great seal, bike was ok,, but the bandage has just disintergrated. lol.
So now we gnna make some tubin (grandad is metal engineer, so he wil have something :P) so thats all sorted :) hopefuly lmao!
Josh
frankie, will be clamped on :) you beat me lol
a lot of OE gaskets are made like that beleive it or not it might just be the OE gasket :?
try your local dealer to see if you can get a new one
a whole set of new clamps, gaskets and seals ordered today..
£29 inc p+p :) should be here within 2-3days ;) was shipped out today tho soo might get it tomorow lol. :)
Josh
