splang Posted November 21, 2009 Posted November 21, 2009 Hi all,My hot grips are not working - I get a flashing blue light when I turn on the power. Even when engine reving still wont turn on.Normally a flashing blue light means not enough voltage.I have checked with a multimeter and I am getting plenty of juice to the socket and from the battery. 12.3 when off from the battery and 14.4 when revving the engine. I have checked the power cable that it is plugged into and i am getting the same amount from this also.Any plans?CheersSteve Quote
Guest Posted November 21, 2009 Posted November 21, 2009 Only time that has happened to me, was with a drained battery. Sounds like you have done the sensible checks. Have you tried charging the battery? Quote
splang Posted November 21, 2009 Author Posted November 21, 2009 Its a new battery (ish) the first one failed on me... this one is one month old.I haven't tried charging it but would it need a charge if it was producing these voltages on my meter?Thanks for the reply Quote
Guest Posted November 21, 2009 Posted November 21, 2009 Just a thought matey .... Have you checked all connections to grips?From battery to first lead. Then the other two? Maybe a spray of WD40 into connections in case water has got in?Otherwise sounds like the control unit itself has gone a bit iffy ...EDIT: whereabouts in the world are you?? Quote
Guest Posted November 21, 2009 Posted November 21, 2009 Jade Mongoose had a dodgy unit, called Oxford Products and they sent a new unit, thats if the units faulty.... Quote
Guest Posted November 21, 2009 Posted November 21, 2009 the latest oxford grips have a low battery sensor in them,maybe it's related to that,also last year Oxford had a batch of faulty control units http://www.oxprod.com/index.php?pg=92 Quote
TC Posted November 21, 2009 Posted November 21, 2009 Are you trying to turn them on with your lights already on. On My old bike the heated grips used to do that, turn everything off so the only thing thats taking power from the battery is the Heated grips, you may have to give a little rev to get to power through. Once they are on i had no probs after that. Quote
Guest Posted November 21, 2009 Posted November 21, 2009 Like you and other people have said, I've only had this issue when battery gets low... revving helps... maybe it could be one of the dodgy batch? Quote
Pete Posted November 21, 2009 Posted November 21, 2009 Isn't 12.3 a bit low for a battery? I replaced my last one when it got to about that level (not enough power to even start the bike let alone run heated grips) and currently (no pun intended!) I'm getting 12.8 on my new one EDIT: Just checked my Haynes and it says an uncharged battery is anything below 12.3V so if it were me I'd get that battery on a trickle charger fast! Quote
Guest Posted November 21, 2009 Posted November 21, 2009 12.3 volts would indicate a 50% charge,have you got a battery optimizer i.e optimate Quote
Ashaman Jay Posted November 21, 2009 Posted November 21, 2009 My dero wouldn't go above 12.3v (ignition off) for ages cos the guy I bought it off garaged it for 2 months without taking care of the battery.When I went out on it the oxford grips worked fine, even with a low battery.Bought an optimiser and the battery recovered eventually, but it took fookin ages. Thought a cell was dead and was very surprised to see a green light one morning. Quote
splang Posted November 22, 2009 Author Posted November 22, 2009 I Went out last night and bought a charger/optimiser and charged it up - green light after about an hour....Now showing plenty of volts and still same thing from the grips....must be a faulty control.Cheers for help guys - will contact oxford. Quote
uktriggersm50 Posted November 24, 2009 Posted November 24, 2009 nothings wrong you just have to start riding for 100 yards then press button then they come on. thats what i have to do but then they will stay on (if i want them to) when the ignition is turned off. so try that Quote
splang Posted November 25, 2009 Author Posted November 25, 2009 thanks but tried that still no joy. Quote
dex Posted November 25, 2009 Posted November 25, 2009 If you can find contact to send the unit to or to get in touch with about returning the control can you post it up please? Mine have just started doing exactly the same thing - even engine running 14.4v at the battery Quote
Guest Posted November 25, 2009 Posted November 25, 2009 http://www.oxprod.com/index.php?pg=6oxprod is the web name... Quote
