blakeatron Posted November 21, 2009 Posted November 21, 2009 Been on the fence about adjusting my suspension but decided it has to be done The front is very spongy - dipping heavily even under light breaking, and the rear seems ok I suppose although it does drop a lot when I get on!SO is there a recomended method of adjusting it or do you just tweak things until it feels 'right'?On another forum a member with a similar bike who is of a similar size just said to click everything up 4 and that should be fine - is this worth a shot? Quote
Guest Posted November 21, 2009 Posted November 21, 2009 Not the recommended way I believe. First thing they say to do, is record where everything is, right now, so you can always go back to a start point....gimme 5 mins, i think i got an article somewhere ...EDIT: found article, gimme 10 to photo it and upload it etc ... Quote
blakeatron Posted November 21, 2009 Author Posted November 21, 2009 hmmm - its straight from the factory - would it all be on 0?I would count the twiddles and clicks of everything I did, I am slighty anal about things like that Quote
Guest Posted November 21, 2009 Posted November 21, 2009 damn camera battery flat... gotta go scan it... gimme 5 lol Quote
techno Posted November 21, 2009 Posted November 21, 2009 Best just take it to someone who knows what there doing I had my zx6 tweaked and it was way better!And keith had the fazer done by a pro, and that had a spectacular effect....how do you test it ride the same bit of raod over and over again?? Quote
Guest Posted November 21, 2009 Posted November 21, 2009 right... dunno if you'll be able to read this. But like Tenko says.. might be better if a pro did it... Quote
Stu Posted November 21, 2009 Posted November 21, 2009 http://www.themotorbikeforum.co.uk/view ... =27&t=2763 Quote
blakeatron Posted November 21, 2009 Author Posted November 21, 2009 Ah man I hate reading things!SO where would I find a specialist? Quote
techno Posted November 21, 2009 Posted November 21, 2009 Ah man I hate reading things!SO where would I find a specialist? Theres one in bradford lol Quote
Guest Posted November 21, 2009 Posted November 21, 2009 Theres one in Atherton nr Manchester ride in ride out service £40 http://www.kais-performance.co.uk/ Quote
Pete Posted November 21, 2009 Posted November 21, 2009 I'm going to try this! Thanks Dan (and Stu for the in depth bit) ! Quote
