Peach Posted November 23, 2009 Posted November 23, 2009 Hi AllHas anybody heard where you can get a 12v Socket (Cigarette Lighter) to connect to a bikes battery. It is to charge/use a camera battery whilst on the move Quote
Guest Posted November 23, 2009 Posted November 23, 2009 yep, try ebay.look for the weatherproof ones, and fit it under the seat,..if its occasional use, then theres no need to fit a switch/relay.. just plug in http://shop.ebay.co.uk/i.html?_nkw=12v+ ... &_osacat=0if you get a bog standard one, then put it in a bag, to keep it dry, few people on here with them for satnavs etc.. Quote
Guest Posted November 23, 2009 Posted November 23, 2009 yep, halfords, look for same as whats on ebay adverts. saves on postage.. Quote
Guest Posted November 23, 2009 Posted November 23, 2009 Camping and caravanning places stock them too. Also check out car boots. I picked mine up for £3. What I did with mine was ... because i use an optimate, I went to maplins and bought a bag of 12v power plugs. Cut off the optimate plugs to use these instead. Put same plug on the cigar socket, so it plugs into lead that would normally plug into optimate. Instant power straight off battery. I also got some croc clips with same plug on end.. Can be used to dispense power or accept power in the event of a flat battery and need a jump. All without removing the saddle etc.May be of some use to you! Quote
Guest Posted November 23, 2009 Posted November 23, 2009 Camping and caravanning places stock them too. Also check out car boots. I picked mine up for £3. What I did with mine was ... because i use an optimate, I went to maplins and bought a bag of 12v power plugs. Cut off the optimate plugs to use these instead. Put same plug on the cigar socket, so it plugs into lead that would normally plug into optimate. Instant power straight off battery. I also got some croc clips with same plug on end.. Can be used to dispense power or accept power in the event of a flat battery and need a jump. All without removing the saddle etc.May be of some use to you! ahh sneeky, so instead of the optimate block connector, you have a universal, likey, likey, could ve done with a jump set for Techno... i haven't got the biggest guns for pushing him round a filling station all day... (cap guns, before anyone takes the pi55, built for speed, not power), Quote
Guest Posted November 23, 2009 Posted November 23, 2009 yep thats it. (cap guns ... pmsl)Changed all the plugs. I still plug into optimate.. but the lead will take any of my other accessories, cos I changed all them plugs too.All lived in a bag under my seat .Along with a cargo net with no hooks .... Yet to sort out the Tiger. Only picked it up earlier Quote
Guest Posted November 23, 2009 Posted November 23, 2009 yep thats it. (cap guns ... pmsl)Changed all the plugs. I still plug into optimate.. but the lead will take any of my other accessories, cos I changed all them plugs too.All lived in a bag under my seat .Along with a cargo net with no hooks .... Yet to sort out the Tiger. Only picked it up earlier s'pose you'll have more underseat space on tigger, has theWife tried it for size yet... Quote
Guest Posted November 23, 2009 Posted November 23, 2009 Yeah, was funny Her little legs dangling away ........ Quote
Guest Posted November 23, 2009 Posted November 23, 2009 no different than the ER6f then... ROFLMAO, soz, Quote
Guest Posted November 23, 2009 Posted November 23, 2009 maplins link..http://www.maplin.co.uk/Search.aspx?menuno=13104 Quote
Peach Posted November 28, 2009 Author Posted November 28, 2009 Thanx for all the advice, now got one on order Quote
