NearOn Posted December 19, 2009 Posted December 19, 2009 Just after some advice, obviously has been very cold and snowing. My bike lives outside in this covered up, 08 Honda vaardero 125. Used it about a week ago, maybe bit longer. Thought id start it up today, but wont start. The lights come on the instrument panel when turn the key and as always neutral light stays on. However when ignition switch is pressed, bike just makes a loud unpleasent clicking sound from under the seat, which i think is start motor. The bike has no kick start or choke and has fuel in it. Im no mechanic, and know very little, my only guess is the battery is flat but wouldent that mean no lights etc? Any other help be great, as dont fancy calling out honda breakdown service if something i can fix.Cheers Quote
Guest Posted December 19, 2009 Posted December 19, 2009 The clicking you describe is symptomatic of a flat battery mate. Get it charged asap and should be fine OR ,, your battery is now dead as a dodo and needs replacing. Charge it first! Cheapest option! Quote
asharin Posted December 19, 2009 Posted December 19, 2009 You can have enough battery power for lights, but not to start the bike. Used to happen all the time on my old Yamaha I'd say just bump start it, but those varadero's are pretty heavy, aren't they?Time to get charging!-edit beat me to it Dan! Quote
Guest Posted December 19, 2009 Posted December 19, 2009 the starter relay hasn't enough power to spin the starter gear, hence the clicking... Quote
killmach Posted December 22, 2009 Posted December 22, 2009 Iv'e been tryin to get on top of mine for years, cause mine constantly lives outside. I've bought two new battery's, and have discovered that if i don't use my bike every day summer and winter, the alarm i have on my bike will kill the battery in a week due to the constantly flashing led light. so now i've bought an oxford oximiser and keep my battery off my bike till i'm gonna use it alot. The only thing i've found is that if i try and start it from dead cold(like now), the battery will probably not have enough power straight away to start the engine that has stood for some time, so i usually bump it first off to keep the battery full. Then after using it for a few day's it's fine. If i leave it two weeks it's dead again, so i just take it off and charge it indoor's.Don't know if anyone's got any more advise for me, would be gratefully recieved. Quote
rennie Posted December 22, 2009 Posted December 22, 2009 batteries don't like the cold!an optimate is the way forward!failing that, if you're not going to use bikefor a couple of weeks take battery off and putsomewhere warmer Quote
killmach Posted December 22, 2009 Posted December 22, 2009 batteries don't like the cold!an optimate is the way forward!failing that, if you're not going to use bikefor a couple of weeks take battery off and putsomewhere warmer Oximiser does the same job as an optimate doesn't it ? Quote
Colin the Bear Posted December 22, 2009 Posted December 22, 2009 Sounds like your battery has had it. A full charged battery in good condition should spin the engine no problems, till it primes and jumps into life. New plugs always help with poor starting reducing the drain on the battery. Quote
Paul Posted December 22, 2009 Posted December 22, 2009 I had exactly the same thing on my old Kawasaki. Went and bought a new battery and it was fine. Got rid of it after that though, for something newer and more reliable. Quote
killmach Posted December 22, 2009 Posted December 22, 2009 Sounds like your battery has had it. A full charged battery in good condition should spin the engine no problems, till it primes and jumps into life. New plugs always help with poor starting reducing the drain on the battery. I havn't tried it since getting the oximiser, but it's a pretty new battery so it shouldn't be a problem. Not sure if my old charger was doing it's job though. I'll let you know what happen's when i try it.I do know the oximiser has recognised the battery as fully charged though Quote
hurtank Posted December 27, 2009 Posted December 27, 2009 find a hill. push it down. stick it in gear. stay shiney side up. ride away into the wintery blinding sunset Quote
