kojak_79 Posted January 2, 2010 Posted January 2, 2010 At the moment in the cold weather if i leave my bike more than a day i seem to be getting water in the float bowl of the carb wich i need to drain before it'll start, I've tried wrapping the tank with a towel and putting the bike cover on but it hasn't worked. Just wondering if any ones got any tips and wether it'll be condenstaion from the tank or from the carb.Cheers Quote
rosszx9r Posted January 3, 2010 Posted January 3, 2010 At the moment in the cold weather if i leave my bike more than a day i seem to be getting water in the float bowl of the carb wich i need to drain before it'll start, i'd be very surprized to find it is water!are you sure it's water?do you turn the fuel tap off at night?if the float valve in carb isn't seating properly and you leave the fuel tap on, you'll over fill the carbs so draining them down would allow the bike to run properly. this is just a guess but far more likely than water building up in the carb after a day or so.if it really is water then it could be from the cooling system. what bike is it and how old is it Quote
kojak_79 Posted January 3, 2010 Author Posted January 3, 2010 It seems like water when you drain it, it's clear and seperates from the petrol. I don't switch the fuel tap off. It's a 2001 nsr 125.Cheers chris Quote
Colin the Bear Posted January 3, 2010 Posted January 3, 2010 I can't think how water would get into your petrol from the cooling system. Is rain getting in through the filler? Quote
kojak_79 Posted January 3, 2010 Author Posted January 3, 2010 Don't think it's from the cooling system as the water is clear not blue. It's only happened since the really cold weather. Once it's drained it runs fine Quote
rosszx9r Posted January 4, 2010 Posted January 4, 2010 I can't think how water would get into your petrol from the cooling system. kwakers use the cooling system to stop the carbs icing up. twas just an idea before knowing what bike it was i'd suggest you drain the fuel tank down completely and refill with fresh petrol. Quote
