What should i do to give my bike some TLC?
someone suggested greasing the brakes for example how would i do that also what other stuff should i do that is neccasary?
Also my brakes are squeaking a little could that to be with the greasing that needs applying???
Thanks in advance,
Sam
Thanks in advance,
Sam
remove the brake pads and inspect, add copper grease to the back side, this will stop the squeak..
oil/filter change,
air filter
plug,
its belt drive? so just inspect.
and you could change the brake fluid. (every 2 years)
grease pivot points such as sidestand, mainstand and footpegs.
