Passed the bugger!
Had to go around on the hazard avoidance again after getting clocked @ 49kph.
Through at 58 second time, 57 on the emergency stop.
If its any help, practice and practice some more getting your revs/brake application right for the slow stuff and open up the throttle in 2nd off the bend for the hazard and emerg bit, throttle off as you go through and you should hit the min 50k (+) no problem.
If there is the slightest possibility of having a practice on the actual test area prior to testing...take it!...If I'd been able to I'm pretty sure I wouldn't have ballsed it up the first time, despite a good dozen successful go's practising away from the test area. I was focused so much on getting around the curve at 20mph and coming out right as I hadn't done it before I went braindead for the hazard avoidance and missed it completely and didn't realise until I was told I'd failed. Mod 2 on Monday.
Good luck!
