Guest Posted March 8, 2010 Posted March 8, 2010 Hi all. Well, i'm looking to put some straight handlebars on my (soon to arrive) Ninja. Its been streetfightered so i'd like the straight bars to go with it. Plus i far prefer them to the racing style ones.Is it possible without too much modding?Heres the bike;http://i115.photobucket.com/albums/n305/CobbZ_2006/5-4.jpgI assume i'd need a new "yoke" assuming thats what its called, the thing attached to the forks that the handlebars attach to. Quote
Guest Posted March 8, 2010 Posted March 8, 2010 yep, you do need a replacement yoke. You could try finding one off another model with similar forks, or try "streetfighter store" Quote
Guest Posted March 8, 2010 Posted March 8, 2010 awhh... Only one i could find is this on ebay;Linky linkBit too expensive right now really. Ahwells! I thought it'd be much cheaper Quote
scrowe Posted March 8, 2010 Posted March 8, 2010 There is another option. go to M&P and for about £40 you can get some bar risers that bolt on to the top yolk ans allow fitment of drag bars. the bars you have are bolt ons so if you are handy (or have a mate that is) you could trim off the bar risers you have that rise from the bolt plates and then bolt on the riser from M&P for the flat bar.another option looking at the photo a bit closer is fabricated 2 base plates the same shape as the bases of the existing bars and attach the risers to them so they bolt straight on to where the old bars bloted on to the yolk! just a bit of billet aluminium and a drill could make something looking really smart and still using the same bolts and original yolk! £40-£80 would do it!it's a bit of work but done right won't cost the earth and all polished up would look the mutts! Quote
Guest Posted March 8, 2010 Posted March 8, 2010 also, remember that if the bars are taller than stock you may need longer cables/brake lines as well.. Quote
Guest Posted March 8, 2010 Posted March 8, 2010 buy a 2nd yoke from evilbay a set of risers and make freinds with the drill.I would replace the steering head bearings at the same time.if you go down this route, I may have a set of drag bars in blue, Quote
Guest Posted March 8, 2010 Posted March 8, 2010 Definately worth thinking about...I'll have a think Quote
Foz Posted March 8, 2010 Posted March 8, 2010 How can u hate it that much customizing is a bug! once its bit its stuck!! with my bike, all i did was replace the air filter cove, had no experience wih messing about with bikes or customizing of ANY kind what so everr...then 4 months later i'd done this list:Custom Seat----------------DoneNew Bars-------------------DoneNew Risers------------------DoneNew Grips-------------------DoneNew air filter cover----------DoneK&N filter-------------------DoneForeward controls-----------DoneRespray tank----------------DoneRespray body work-------- --DoneSpray cooling fins------- ----Donepipes------------------------Done needless to say i'm skint! bikt looks alright though Quote
