hi my chrome rusts easy so i got some acf-50 spray.now do i take the rust off shine it up then spray of take rust off spray and then shine or what?
Take the rust of first, get your entire bike in a clean condition then spray it on. ACF50 is meant to keep rust from forming by creating a protective layer. I'm pretty sure it can't be used to remove actual rust :lol:
hope this helps.
ACF50 is pretty good gear.
Clean bike, dry bike, remove rust, polish bike.
Apply ACF50.
Keep it away from the brakes. And note, you do not need a lot. It may be sensible to spray some in the lid and use a brush because you will waste loads otherwise.
and yes, I do use it.
(and moved to pitstop for ya :thumb:)
You don't need too much Dan, one can can too about 2 bikes if you're lucky.
You can either be frugle or wasteful :thumb:
That'll be frugal then :mrgreen:
:tumble: :scratch:
Wot??
and i really need to get me some acf 50, but late now the winters basically over now ! lol
another product worth using is scotoiler fs365 spray. it nutralizes salt and leaves a good barrier against dirt. it's water based so it dries on a hot engine but is easy to wash of.
