cyberwolf Posted March 25, 2010 Posted March 25, 2010 any help would be grateful my car wont start from cold, it starts ok when warm only way i can get it started from cold is to push start it,its a diesel could this be it needs new glow plugs? Quote
Guest Posted March 25, 2010 Posted March 25, 2010 You know when you turn the ignition on, and you watch the little light on the dash that says it is warming the glowplugs?Try this twice.... ie turn key, let glow plugs warm, turn off, turn on, let glowplugs warm ... try to start ...see if it makes a difference. Quote
cyberwolf Posted March 25, 2010 Author Posted March 25, 2010 yeah iv tried that even doing it 7 or 8 times still doesnt work Quote
Guest Posted March 25, 2010 Posted March 25, 2010 first thing i'd be looking at then is glowplugs wolfie ... dunno what sort of a job that is on yours, or how much ... Quote
cyberwolf Posted March 25, 2010 Author Posted March 25, 2010 ok thanks dan £21 for 4 glowplugs on ebay i get some news one see what its like prob be next week now unless i go out tomoz loljust hope i can find were they would go lmao Quote
Guest Posted March 25, 2010 Posted March 25, 2010 Can't grumble at £20 mate!And go buy a haynes lol Quote
cyberwolf Posted March 25, 2010 Author Posted March 25, 2010 Can't grumble at £20 mate!And go buy a haynes lol that prob cost more then what the car is worth good job i have a bike to fall back on lol Quote
iMIKE.RD.125.LC.MK2 Posted March 25, 2010 Posted March 25, 2010 good job i have a bike to fall back on loldont want to do that mate you might knock it over Quote
rennie Posted March 26, 2010 Posted March 26, 2010 If it's not the glow plugs it will probably be a blocked fuel or air filter!there's quite a few filters in the fuel lines!Diesels are harder to start than petrols!Is yours the older 1.9 TDI wolfie?I've got a 2.0 HDI now, good engines! Quote
cyberwolf Posted April 4, 2010 Author Posted April 4, 2010 problem still not fix, but i can get it started now with some help from my trusted lil friend Quote
splinter Posted April 4, 2010 Posted April 4, 2010 Im edging my bets towards the battery pal, deisels are renowed for it Quote
Stu Posted April 4, 2010 Posted April 4, 2010 did you get new glow plugs for it ?some diesels pre heating systems work in conjunction with the coolant temparature too so a new coolant sensor maybe in order Quote
cyberwolf Posted April 4, 2010 Author Posted April 4, 2010 it as new battery.iv got 2 new glow plugs in couldnt get at the other 2 glow plugs as would mean taking of most of the fuel system!stu could be that as im getting warning light flashing on the dash but know idea what the warning light means, doesn't say in the manual Quote
Bill_on_a_bike Posted April 4, 2010 Posted April 4, 2010 If you've got a multimeter you can test glow plug, just check for an ohm reading.It starts on a bump though, which makes me think maybe the starter's a bit weak, does it turn it over fast enough?Easy start is useful stuff but it can and will damage things if its used excessively. Quote
cyberwolf Posted April 4, 2010 Author Posted April 4, 2010 iv been told it could be low cylinder pressures im waiting for someone to look at it, when he gets the time Quote
