Anyone use the Gripster pads, specifically the snakeskin variety? If so are they as good as I've heard - i.e. once you've ridden with them for a while, you won't want to be without them.
Guest philgale
i use stomp grips on both track and road bike, wont be without them.
http://www.blueridgeperformance.net/images/Stompgrip-3.jpg
I was looking at them first, but was told its a PITA to apply the clear ones without bubbles and the black ones don't do it for me. I'm guessing all those sort of products will work within a similar tolerance though.
Do the stomp grips stop you from riding forward under heavy braking?
Guest philgale
yes mate, saves the family jewels a few times...also more stable in corners if you clamp your leg to it
