DeeJ Posted March 28, 2010 Posted March 28, 2010 I am looking at a bike which is to be unamed atm, it has had a GSX front end fitted but is not a Suzuki. The main problem is that the GSX has a speedo sensor on the sprocket cover, and the bike use to have its speedo sensor on the front wheel.Can a sensor be fitted on the GSX front wheel so the standard speedo off the bike can be used which is digital.The bike is goin to be my little project and I don't want to announce it until its up and running Quote
Guest Posted March 28, 2010 Posted March 28, 2010 ok, i take it the front wheel is a GSXF or GSXR, as the GSX has a cable driven speedo off the front wheel.you could fit a bandit 600 pre 2000 front wheel and sender.. or go for an electronic one like streetfighters do.. works off a magnet fitted to the wheel rim.. Quote
