rev counter light
hi, can anyone help, new to biking ( passed test 2 months ago ), have got a 2005 er 500 and the rev counter light has just popped, is this easy to replace and how?
thanks
hogiesuk
lower the headlight, and remove the rev counter cable, then undo the screws that hold on the lower housing to access the cables, pull out light swap bulb.. TEST, then put back together..
the bulb is cap less and is identical to a side light bulb from a 300tdi land rover discovery. There were three blown on my dads er5.
thanks worked a treat and nice and bright now, till the humps blow them again
