Replacing Chain and sprocket on fazer 600
Hi
I want to replace the chain and sproket on my 10 year old fazer 600, do I have to take off the swing arm to do this? I take it the shock would have to come out as well?
TCW
No, just take off the rear wheel and the sprocket should come straight off (IIRC)
The front sprocket i have heard can be a bit of a pain though, as you may need an impact drill to remove the bolts? Although im not too sure..
Might be a good idea to invest in a haynes manual and follow pictured instructions! :)
No worries :thumb:
If ya get stuck or have questions, just ask!!
If I remember correctly, you have a fazer as a restoration project or similar? Best bet is start a thread along those lines.
'my fazer restoration' or something. then all your questions and stuff will be in one place!!!
