YBR 125 Not starting
It seems as the fuel pum is priming but no fuel is getting injected through. Would this be a sensor or the actual injection module playing up, it was intermitant but now a constant problem. thanks for any ideas
Is the starter motor turning over the engine? Is there any firing?
Need a lot more details to help you out there!
hi, engine turns over, and spark plug firing (took out to check ) pump primes, but engine does not start i guess fuel not getting called for from injector, is that aproblem with ecu or injector itself?
thanks
The injector may have failed.
Have it checked out, replace the injector as it sounds like that has packed up. If that doesnt work then look into the ECU. It has to be one of the 2...
Also, just to clear up any other silly possibilities, you havent got a fuel tap have you and switched it off rather than to res or on? Just a possibility. Please check it.
Kill switch?
What about your kick stand? How is the battery?
Try and bump it!
hi, thanks for info. will try and check out the injector with meter and copare readings with manual info. there is no fuel tap or kill switch on this bike, bit strange but original i believe. thanks
