Guest Posted May 13, 2010 Posted May 13, 2010 Maybe you guys in the UK can help me out. I am working on a 02 gsx600f. The problem , idles ok, won't take any throttle, when wicked wide open it bogs and revs up and down fluctuating around 3to4 thou rpm. I have replaced the ignition controller and checked the tps. I'm assuming the tps is used for ignition advance. The air box is off and I can observe the slides which rise evenly untill you raise the rpm over 3 thou rpm then they settle to about a quarter open and mixture will blow out the carb bell. I am running fuel from a container directly to the fuel supply inlet at the carb so I know it's not starving for fuel. This problem arose overnight as it was running fine when shut off that evening and was a problem when started the next morning. So it was like throwing a switch overnight. Man if you can help me it would be great. Any suggestions? Quote
