Guest Posted May 14, 2010 Posted May 14, 2010 i am in the process of getting my sv back on the road and while working on it in a damp dark garage (any excuse possible) i lost all rational trail of thought and connected the battery the WRONG WAY WRONG!!PLEASE LAUGH i am trying to now there was a small spark and i have not had the chance to have a look all over but i do need advice on what to look for i will check the fuses but if that fails what else would i need to be looking at??? and do i need to change the battery as well??i am open to all abuse and help if you can help me please do message back the more advice the better STEVE x Quote
Guest Posted May 14, 2010 Posted May 14, 2010 the battery should be fine, but before you put it back in, make sure that the fuses are all fine, and it should have made no difference whatsoever, i've done it before on my car and it didnt do anyhting to it. Quote
Guest Posted May 14, 2010 Posted May 14, 2010 It degrades the battery so try not to do this any more. Check the fuse next to the battery. There should be a 30A there I reckon.yaro Quote
Guest Posted May 15, 2010 Posted May 15, 2010 EXCELLENT!!!! thanks lads appriciate the advice cheers for answering my post ... quite lucky tho that its a 99 model theres not alot of tech electronics like the newer one heard this can be expensive on newer bikes cheers again steve Quote
