Guest Posted August 8, 2010 Posted August 8, 2010 hi there does anyone know how easy it is to remove the chain off a yamaha sr 125 and shorten the chain, what tools are needed etc as mine is at the end of its adjustment, cheers Quote
eastanglianbiker Posted August 8, 2010 Posted August 8, 2010 if you have run out of adjustment chances are it is time for a new chain and sprocket set Quote
Guest Posted August 8, 2010 Posted August 8, 2010 Tools required;Hacksaw.Method.Rub the hacksaw up and down repeatedly on the chain xD Glad i could help!! EDIT: And as eastanglianbiker says, you don't shorten motorbike chains, its just not safe and isn't work the risk. It will cost you about £30 for a new chain and sprockets set off ebay.270473427592 <--- search that number on eBay, thats the one you want. Quote
