Guest Posted March 26, 2007 Posted March 26, 2007 what a bugger to get out!!!!the preload adjuster gets in the way and it can't be tilted to clear the frame!! the answer???remove the linkage plates and lift the wheel(and swingarm)as high as it will go,prop it up,and hey presto!!!you can waggle it thro the bottom it does help if you remove the knob from the adjuster first,,,,thank goodness the new hagon has'nt got one,,,,, Quote
Guest Posted March 29, 2007 Posted March 29, 2007 the new shock????dropped in no probs!!!!bike is even higher now,,,,,just gotta road test it next week,,oil change before then tho,,,,,,,, Quote
