NearOn Posted October 5, 2010 Share Posted October 5, 2010 I have bought a replacement fuel cap second hand for my hornet. It came off a 98 Hornet and mine is 99. Obviously my key wont work as different barrell lock. It didnt come with a key, so my only option is to change the lock barrell so take my one out and fit into new fuel cap. However I cant see how to do it? I was under impression there would be a circlip sort of thing but only similar thing can see to that is a plastic cap on bottom of lock, do i need to remove this to do it? Quote Link to comment Share on other sites More sharing options...
Guest Posted October 5, 2010 Share Posted October 5, 2010 Normally insert key, insert pin (unfolded paperclip works) in hole (near key) and withdraw lock, but never done it on a fuel lock. dont mix this up with breather hole... Quote Link to comment Share on other sites More sharing options...
NearOn Posted October 6, 2010 Author Share Posted October 6, 2010 Ill give it but dont have original key for the lock I have just bought. Might try post some pics,see if that helps. Quote Link to comment Share on other sites More sharing options...
Guest Posted October 6, 2010 Share Posted October 6, 2010 or change the filler and live with another key Quote Link to comment Share on other sites More sharing options...
NearOn Posted October 6, 2010 Author Share Posted October 6, 2010 I have changed the filler cap tho, thats whole point, dont want to end up buying a third fuel cap. Must be a way to change the lock, what goes in must come out. Quote Link to comment Share on other sites More sharing options...
argentum40 Posted October 6, 2010 Share Posted October 6, 2010 I have changed the filler cap tho, thats whole point, dont want to end up buying a third fuel cap. Must be a way to change the lock, what goes in must come out. if the barrel is removeable it may need the key to remove it along with the pin/paper clip as mentioned earlier Quote Link to comment Share on other sites More sharing options...
Guest Posted October 6, 2010 Share Posted October 6, 2010 how goods your drill? drill kill the lock and remove Quote Link to comment Share on other sites More sharing options...
NearOn Posted October 7, 2010 Author Share Posted October 7, 2010 Want to try avoid drilling, the guy got it off is going to get back to me as he might know. Quote Link to comment Share on other sites More sharing options...
