wannars125 Posted November 9, 2010 Share Posted November 9, 2010 Quick question, I've got to do some maintenance on the forks and haven't done anything like this before. The service manual gives me the required amount of fork oil to put back in the fork but says to check it with a measuring guage to check it's at a certain level.Question is, if I've followed what it says and filled it up with equal amounts of oil on both forks it should be ok right?You may say get the measuring guage but at over £200 for a the tool, there's no way I'm spending that kind of money!The Haynes manual doesn't mention about doing this check either. Quote Link to comment Share on other sites More sharing options...
Guest Posted November 9, 2010 Share Posted November 9, 2010 Not necessarily, There could be some gunk, or dirt or some kind of solid material at the bottom which will affect the level of oil in the fork. Hence the measuring tool. Cant something like an oil dipstick be used? Why is this tool £200?go to a garage? Quote Link to comment Share on other sites More sharing options...
karma Posted November 9, 2010 Share Posted November 9, 2010 If I rember correctly, the measuring guage is used to measure from the top of the forks to the top of the oil when you have re-filled. I did this a couple of years ago on a VFR without a £200 tool. I used a Steel rule with fine increments on.Dave Quote Link to comment Share on other sites More sharing options...
Martyc Posted November 9, 2010 Share Posted November 9, 2010 Isn't it measured by the air gap at the top, I.e with a ruler? Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted November 9, 2010 Share Posted November 9, 2010 when i have done them in the past i done it with fork leg fully pushed down into lower leg(compressed), filled to top edge then expanded fork leg to full extent inserted spring and put fork top back on never caused any problems Quote Link to comment Share on other sites More sharing options...
wannars125 Posted November 9, 2010 Author Share Posted November 9, 2010 Some sound ideas. I think the tool is so expensive because it's a genuine suzuki one. Quote Link to comment Share on other sites More sharing options...
Phill_vtr Posted November 11, 2010 Share Posted November 11, 2010 I use a syringe (borrowed from work) with a bit of tube on it. Measure from the end of the tube, a distance equal to the air gap and mark the tube with a line. Once the correct amount of oil has been put in, pump the fork inners a few times to get the oil in and the air out. Before you put the springs back, compress the outer (this is true on my bikes but don't know if it's true on all bikes) and put tube into fork leg until mark is flush with the top and draw out excess oil. If you want a proper tool for this there are plenty of cheaper ones about like http://cgi.ebay.co.uk/Motion-Pro-Fork-Oil-level-tool-Gauge-meter-/190438226783?pt=UK_Motorcycle_Parts&hash=item2c5700bb5f Quote Link to comment Share on other sites More sharing options...
flipper Posted November 16, 2010 Share Posted November 16, 2010 when i have done them in the past i done it with fork leg fully pushed down into lower leg(compressed), filled to top edge then expanded fork leg to full extent inserted spring and put fork top back on never caused any problems Then you have too much oil in the fork. The oil should be filled to the height specified with the leg compressed and spring removed. The tool for measuring oil level can be purchased on ebay for about £12 - £14. Quote Link to comment Share on other sites More sharing options...
wannars125 Posted November 18, 2010 Author Share Posted November 18, 2010 Cheers for the help people! Quote Link to comment Share on other sites More sharing options...
