Guest Posted November 21, 2010 Share Posted November 21, 2010 Hi , I have a Veto Evo alarm fitted to my Triumph RS Sprint, over the winter I do not use the bike and I want to remove battery during this time.................However on taking battery out the alarm goes off, anyone know if you can fully disable alarm to allow battery to be removed....I thought perhaps taking alarm fuse out would be the answer...............cheers Quote Link to comment Share on other sites More sharing options...
Guest Posted November 21, 2010 Share Posted November 21, 2010 not familiar with that model, but a look at the datatool website should sort you out with the support section I'm pretty sure the you can turn em off wit a key press or combination thereof .... Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted November 21, 2010 Share Posted November 21, 2010 not sure how but you should be able to put the alarm in service mode on checking website Quote Link to comment Share on other sites More sharing options...
2fast2soon Posted November 21, 2010 Share Posted November 21, 2010 From the manufacturer's guide:Service modeUse this facility to disable the alarm system eg: when you wish to service or clean your motorcycle, or remove the motorcycle battery.• Disarm the alarm system by pressing the O. • With the ignition switched ON, press and HOLD the O until an audible beep is heard. The ignition can then be turned off.When the alarm system is in Service Mode, the LED alarm indicator on the motorcycle will remain ON and an audible beep will be heard every 15 seconds.In Service Mode, the Protective Trigger Switch is disabled. • To return to normal operation, press the O. Quote Link to comment Share on other sites More sharing options...
Revvin Kevin Posted November 21, 2010 Share Posted November 21, 2010 After putting the alram into service mode, just leave the internal battery to drain, it takes upto 12 hours then the beeping will stop. Quote Link to comment Share on other sites More sharing options...
