Ricco1 Posted December 6, 2010 Share Posted December 6, 2010 I ride a Honda 160 Megapro here in Indonesia, which is similar to a CG. Over the last few days I've noticed a squeaking sound when I'm riding the bike. It's like you might hear on a push bike if you hadn't oiled the wheels or something... It's loud enough to be heard when I'm going at 30mph.I've spun the wheels at separately at home, no sound at all! There's no play in the wheels so on the face of it, the bearings seem ok, to me at least. The squeaking sound stays the same, whether the clutch is engaged or not...I'm baffled as to what this might be. Any ideas?Thanks Quote Link to comment Share on other sites More sharing options...
Guest Posted December 6, 2010 Share Posted December 6, 2010 The chain cleaned, oiled and adjusted correctly? Not got dragging brakes? Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted December 6, 2010 Share Posted December 6, 2010 springs on the rear shocks squeaking? Quote Link to comment Share on other sites More sharing options...
Danny-B- Posted December 6, 2010 Share Posted December 6, 2010 Iank's bike i used to ride got bad for squeaking, turned out to be the rear sprocket bearing ... whatever that is It failed the MOT on it. Quote Link to comment Share on other sites More sharing options...
Ingah Posted December 6, 2010 Share Posted December 6, 2010 Iank's bike i used to ride got bad for squeaking, turned out to be the rear sprocket bearing ... whatever that is It failed the MOT on it. Hmm, if it's any help to the OP, i did immediately think of checking all the bearings (after all it's really quick and easy to give 'em a quick check and they are rather important either way )You should replace the sprocket carrier bearing when you replace the rear wheel bearing. I imagine lots of people don't. Quote Link to comment Share on other sites More sharing options...
