  • Sign up now
Bio diesel ,pros and cons
craig
as title says ,does anyone use it or have done in the past.with the cost of fuel going up and up i was thinking of using it in my work van ,its a 2001 citreon relay 1.9 d .I ve heard that should be ok mixed 50/50 to start with .So whats peoples views then :)
If I remember correctly top gear did a episode with a 2nd hand m5? at a racetrack with bio fuel. the fuel ate through something or other.. may have been the gaskets. not certian, but it damaged the car. suppose itd be a hell of a lot cheaper though. its just off £1.30 up here now :(
If you switch to biodiesel get a new fuel filter ready
the biodiesel cleans the crap out of your tank and clogs the filter
you'll need a new one after a few hundred miles
if you make your own biodiesel its
duty free if you make less than 2500 litres /year
Talk nice to your local Chippy , they'll givit to you as it costs them to dispose of it now
That's Veg oil not biodiesel and I'm not making my own its too much messing!
quick update run my van till it was empty and now i have put £30 diesel in and £25 bio been running around for a couple of days and all seems fine :D ............
Stu will send u a PM mate
