alexanderfoti Posted February 4, 2011 Share Posted February 4, 2011 (edited) Hi allJust a quick onewould a remus link pipe fit a devil slip on? I have no specs on either, I may have found a cheap source of the remus pipes This is for my vara 125 btw Edited February 4, 2011 by alexanderfoti Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted February 4, 2011 Share Posted February 4, 2011 would all depend on the end of the link pipe diameter the standard is normally 53mm Quote Link to comment Share on other sites More sharing options...
alexanderfoti Posted February 4, 2011 Author Share Posted February 4, 2011 would all depend on the end of the link pipe diameter the standard is normally 53mm I should be able to coax it together then? Quote Link to comment Share on other sites More sharing options...
Guest Posted February 4, 2011 Share Posted February 4, 2011 'coax'lol I like it Might need a big 'ammer n all Quote Link to comment Share on other sites More sharing options...
Stu Posted February 4, 2011 Share Posted February 4, 2011 would all depend on the end of the link pipe diameter the standard is normally 53mm think you may find it a lot smaller on the 125 they are only thin pipes Quote Link to comment Share on other sites More sharing options...
megawatt Posted February 4, 2011 Share Posted February 4, 2011 You may be lucky mate, but it would probably be cheaper to get me to sort it.Let me know ? You nheed some accurate measurements, diameters and angles??? Quote Link to comment Share on other sites More sharing options...
alexanderfoti Posted February 5, 2011 Author Share Posted February 5, 2011 You may be lucky mate, but it would probably be cheaper to get me to sort it.Let me know ? You nheed some accurate measurements, diameters and angles??? Defo, A bit jam packed this weekend, so I will get the measurments across next week if thats ok? Quote Link to comment Share on other sites More sharing options...
megawatt Posted February 5, 2011 Share Posted February 5, 2011 No probs mate Quote Link to comment Share on other sites More sharing options...
