Guest Posted February 10, 2011 Posted February 10, 2011 I bought a Marushin Ikusa 999I tried it in the shop and it felt OK, perfect fitting except a little pressure in the forehead but nothing dramatical, so I bought it as I really like the design, I found it in an online outlet three times cheaper than in the shop and, specially because how light it is.The thing is, the first time I tried it on a got a bit headache after half an hour and my forehead marked in red, so I decided to sell it in the second hand market.But now I've been reading that if I wear it for longer it may adapt to the shape of my head and end up without feeling pressure anymore.What do you think? I know the cushion can soften and adapt, but in there is almost no cushion in the forehead, just the hard foam and I doubt it will get adapted as it's designed to be deformed only in case of impact isn't it? Quote
PhatDad Posted February 10, 2011 Posted February 10, 2011 Get rid. They're designed to be snug not painfully tight. You should also be able to get a thin layer or two (balaclava etc) on and then the helmet so if it's that tight it hurts you should get rid while it's still saleable. Quote
