wannars125 Posted February 14, 2011 Share Posted February 14, 2011 I've misplaced my owners manual and therefore don't know what the clicks represent when adjusting the rear shock preload. Can anyone help please?Cheers in advance! Quote Link to comment Share on other sites More sharing options...
megawatt Posted February 14, 2011 Share Posted February 14, 2011 If it's similar to my old one, turn the pre load adjusteruntil the compression on the spring increases ie the adjuster has more metal under the bit where the cam touches the detent plate. If you can post a piccy that would help? Basically if it becomes harder to turn , the preload is increasing. I have a manual in my garage if you need any more help Quote Link to comment Share on other sites More sharing options...
Guest Posted February 14, 2011 Share Posted February 14, 2011 Replace it with the shock from a Busa or Gixxer Quote Link to comment Share on other sites More sharing options...
wannars125 Posted February 15, 2011 Author Share Posted February 15, 2011 Cobbz, unfortunately financial restraints prevent an upgrade!I'm familiar with how to change the settings, it's more what the numbers represent in terms of weight that I was after.In all fairness, once I get the luggage and I've got the missus on it's probably going to be at the top end anyway. Quote Link to comment Share on other sites More sharing options...
megawatt Posted February 15, 2011 Share Posted February 15, 2011 You need to adjust it so that the SAG is right, ie it drops about 25 to 35mm when you sit on it. If too low it will be too soft and may bottom out on a bump. If too hard it will be a bit lively on bumpy roads. You just have to adjust it and try it Quote Link to comment Share on other sites More sharing options...
bullet5 Posted February 15, 2011 Share Posted February 15, 2011 Right, I've jsut had a peep in my Haynes for the bandit, and the position / number 1 is the softest and as the numbers increase upto 7 the hardness increases. 3 or 4 are the standard setting. To incease the pre-load, turn the spring seat clockwise. To decrease the pre-load, turn the spring seat anti-clockwise. Rebound damping adjustment is made by turning the adjuster on the bottom of the shock absorber. ON all 600, 650, and gsf1200T/ST to k5/SK5 models there are four positions. Position 1 is the softest setting and 4 the hardest.An audiable clikc is heard when the adjuster is clickeed into place. Do not set the adjuster between two positions. Position 1 and 2 are standard settings, to increase damping turn the adjuster clockwise. And Vice Versa. Hope this helps.Bullet5. Quote Link to comment Share on other sites More sharing options...
wannars125 Posted February 15, 2011 Author Share Posted February 15, 2011 Cheers Bullet, I got the same from my Haynes but I was led to believe that each click represented a certain amount of weight. I could however be wrong and it just needs to be done by trial and error.Do you have the owners manual at all? Quote Link to comment Share on other sites More sharing options...
bullet5 Posted February 15, 2011 Share Posted February 15, 2011 I believe I do, I'll go look for it in a second, I just need to put the bike in the garage 1st. What do you want to know from it? Quote Link to comment Share on other sites More sharing options...
wannars125 Posted February 15, 2011 Author Share Posted February 15, 2011 Just if the different clicks relate to different weights or if it just says that it's 1 for soft and 7 for hard!Muchos gracias! Quote Link to comment Share on other sites More sharing options...
Stu Posted February 15, 2011 Share Posted February 15, 2011 ive never seen in a manual clicks to weight its always soft to hard you dont set compression and rebound to weight you set sag to weight then control the speed at which the shock bounces with the compression and rebound adjusters till you find that purfect ride Quote Link to comment Share on other sites More sharing options...
wannars125 Posted February 15, 2011 Author Share Posted February 15, 2011 Cheers Stu!!! Quote Link to comment Share on other sites More sharing options...
