Was balancing the carbs earlier, Been having issues with it not running right, Noticed the mix screw had to go in a fair bit, but also theres fuel coming up the vaccum line for balancing it, only happens on that carb, Is that a sign that its drawing too much fuel?
It's a sign that the float valve is open too far mate. Checkout the float level/position of the tang on the float pivot and compare it with the others. Check the seat and tip of the float valve for crud? :mrgreen: :mrgreen: :mrgreen:
seems fine, isnt coming out the overflow either, Already gave it a right good clean. Its holding the revs for quite a while if i blip the throttle aswell
You need to remove carbs , strip n clean em mate. Check diaphragms n seats especially. Usually you don't find anything, but it often fixes it??? :mrgreen: :mrgreen: :mrgreen:
