Breakdown!!
Guest Budgie_Blizzal
Peugeot elystar 125efi (2004)
My bike was running fine until recently the battery light kept coming on every day and then one evening I noticed that all my lights were getting dimmer until it just cut out, not had a bit of life out of it since, battery is fairly new!! Any help would be greatly appreciated???!!!
Hello mate. It is polite to say hello and read a bit first. There is section here for any technical problems called Pitstop :wink:
Was the batt charged fully before putting in? If not that could be ya problem and ya killed it. Alternatively the charging system is fooked, they would be my 2 guesses
Moved into pitstop for you.
Why not pop into newbie bit and say Hi!!
That a scoot? Sounds like it isn't/hasn't been charging ...
Consider me told off, hi my names Lee!!!
Had the battery off on a charger and it just still no life, could the battery just be completely bushed??
If the battery won't accept a charge then it's no good!
but you need to check out the charging system on the scoot
before you put a new battery on or it might fry that too!
I would bet £10 its the alternator. a running engine always needs electricity for the spark plugs. Normally the alternator will provide enough power for the spark plugs, auxillary power consumption (lights, indicators) and to charge the battery up (since the battery needs charging after initial start up), do what rennie surgests, and if the alternator isnt going above ~13V then its buggered, similarly check the current. check voltage in parallel, current in series. :D
