from all the weather we've had and the amount of salt and grit that gets put on the roads its inevitable that bike are gonna suffer but my bike its a 10 plate bike and the engine is exposed as its a supermoto style so there is alot of bolts and bare metal etc..
and now alot of it has surface rust and it looks S*** to say its a newish bike, does anyone know a way of getting rid of it and stop its rusting again??
any tips and advice would be much appreciated! :cheers:
having the same problem with bolts, axels starting to rust. the areas need wd40 or some other spray on them to prevent further rusting. not sure if you can remove the rust though
Brass brushes, and soft metal wire, then apply lots of ACF50. :twisted: Not a long term solution, but helps greatly. Oh! and swap those monkey metal bolts for some propper, good grade stainless. 8-)
I know how you feel WR125x, my husky SM is killing me the rain and constant salt on the road has eventually taking its time to rust my front exhaust pipe (underneath the bike) plus the stand and wheels spokes have slight rust on them. But as soon as summer comes and the hours of scrubbing the bike will eventually be back to normal. :)
Stainless bolts and a regular clean & polish. ACF50 and you should be fine
:stupid:
What he said
to prevent salt from rusting/corroding the bike frequent washes are good as it removes a lot of the crap from the bike. the only problem is water sits on the bolts and rusts them
:stupid:
What he said
What they said!!
:cheers:
