do1977 Posted April 4, 2011 Posted April 4, 2011 i have a 900cc year 2000 injection blade it has been stood in the garage for a year now and wont starti have tryed every thing and it is not getting fuel but the pump works if you pore fuel into the throttol boddys it starts so it is not the petrol, fuel pump, plugs or coili have moved the auto choke with a screwdriver as i think it stuck and it almost firedthere is no faults on the dashany idears Quote
eastanglianbiker Posted April 4, 2011 Posted April 4, 2011 have you put new clean fuel into it as the old petrol will of gone off by now and if has got fuel filter that might need replacing as well Quote
do1977 Posted April 4, 2011 Author Posted April 4, 2011 have you put new clean fuel into it as the old petrol will of gone off by now and if has got fuel filter that might need replacing as welldone that and a new battery Quote
eastanglianbiker Posted April 4, 2011 Posted April 4, 2011 have you checked the pump is pumping fuel and not just ticking so it sounds like its working Quote
do1977 Posted April 4, 2011 Author Posted April 4, 2011 have you checked the pump is pumping fuel and not just ticking so it sounds like its working yep all ok Quote
eastanglianbiker Posted April 4, 2011 Posted April 4, 2011 sounds like it is problem with auto choke or injectors then or even where the fuel goes into the injectors as the old fuel might of gummed them up where it has gone stale and turned to gel Quote
do1977 Posted April 4, 2011 Author Posted April 4, 2011 sounds like it is problem with auto choke or injectors then or even where the fuel goes into the injectors as the old fuel might of gummed them up where it has gone stale and turned to gel i have moved the auto choke with a screwdriver as i think itmay be stuck and it almost startedi have stripped the injecters out as wellis there any way of cleaning the injecters Quote
eastanglianbiker Posted April 4, 2011 Posted April 4, 2011 you might be able to use carb cleaner in them it might clear them if they are manky apart from that im not sure wht next apart from speak to honda mechanic Quote
do1977 Posted April 4, 2011 Author Posted April 4, 2011 you might be able to use carb cleaner in them it might clear them if they are manky apart from that im not sure wht next apart from speak to honda mechanic they where very clean when i removed them Quote
eastanglianbiker Posted April 4, 2011 Posted April 4, 2011 time to speak to honda guy then unless someone else on here has any ideas Quote
Guest Posted April 5, 2011 Posted April 5, 2011 Megawatt is the next man who might have some info...Sounds like you done everything though fella ..Am assuming you checked that it is actually pumping fuel? No airlocks or anything? Quote
megawatt Posted April 5, 2011 Posted April 5, 2011 Thanks Dan, sounds like autochoke or fuel pump to me. Can you disconnect pump and get it to pump fuel into a container? If autochoke, can you disconnect closing mechanism/spring and see how well it starts. I'll post this question on a coupla Blade Forums, if that's OK Dan??? Quote
do1977 Posted April 6, 2011 Author Posted April 6, 2011 yep pumping fuel ok and no air locksgoing to take injectors out tonight and soke on fresh fuel over nighti even spoke to honda they dont no what it could be but they want to do all the things i have done and charge me for it so going to puch on with it Quote
Guest Hodgy Posted April 6, 2011 Posted April 6, 2011 Daft question, but, on some Honda's there's a tilt switch that cuts the engine should the bike go over, this couldn't somehow have tripped could it? Quote
do1977 Posted April 6, 2011 Author Posted April 6, 2011 Daft question, but, on some Honda's there's a tilt switch that cuts the engine should the bike go over, this couldn't somehow have tripped could it? i think that stops it from sparking and it runs when you put fuel in the inlets Quote
Guest Posted April 7, 2011 Posted April 7, 2011 Daft question, but, on some Honda's there's a tilt switch that cuts the engine should the bike go over, this couldn't somehow have tripped could it? i think that stops it from sparking and it runs when you put fuel in the inlets If the tlt switch stopped it from sparking then it wouldnt run if you put fuel in the inlets, if there is no spark then there is no ignition, some tilt switches cut the ecu some cut the fuel and some cut both, depends on model etc etcHave you checked the fuel pressure regulator?Voltage at the injectors? Quote
Fozzie Posted April 7, 2011 Posted April 7, 2011 Have you checked the kill switch? Some bikes turn over fine with it but arent pumping fuel in... Quote
