ZZR1100D Water and Oil Pump issues
Echoeone
Hi - i have replaced the water pump on my ZZR1100D, because the old one was leaking and also the oil and water was mixing. As I had altready changed the head and head gasket, this looked a likely cause. Having put it all back together, the bike starts but on checking in the rad filler top - there is no movement of water as there normally is. Couple of other things, the red low oil pressure light does not come on before I start the bike up now [ used to so presuming sender ok ] and also if I put the bike in gear [ when the engine is not running ] and pull the clutch in the back wheel is still engaged. As the new water pump is all fitted and engaged to the oil pump, I pressume there may be an oil pump prob - ie if that is not turning then the water pump cany? How would I check if the oil pump is working? Any other thoughts welcome as the old haynes offers nothing in this area
thx
