jacol Posted September 7, 2011 Posted September 7, 2011 I recently realized that my Fazer doesn't start in gear (with clutch pulled in of course). Instead, all lights on the dash light up Is that how it's supposed to be? There is a switch of some sort under the clutch lever which comes out when the lever is pulled in. It seems to be connected to something but I don't know where the other end of that wire goes Quote
Decor58 Posted September 7, 2011 Posted September 7, 2011 Are you making sure to put the side stand up?There are safety devises so that you cannot start the engine while the bike is in gear, the side stand is down and the clutch is out. So if the sensor on the clutch isn't detecting it's in and the side stand is down it will prevent the bike from starting. Quote
jacol Posted September 7, 2011 Author Posted September 7, 2011 Yeah it was definitely up when I tried. If it's in neutral it starts regardless of side stand position. Quote
Colin the Bear Posted September 8, 2011 Posted September 8, 2011 The other end of the wire goes to the battery eventually Quote
