Chimera101 Posted September 16, 2011 Share Posted September 16, 2011 Hi all, I have a few (probably dumb) questions about replacing downpipes.Firstly are there any specialised tools I'll need? and will I need to remove the tank and drain the fuel and oil before hand?I do have a haynes book somewhere, but I'm at work and busy stressing out about it. Any info would be appreciated.Cheers Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted September 16, 2011 Share Posted September 16, 2011 depending on what bike it is you might need to remove fairings and rad if it has them what bike is it Quote Link to comment Share on other sites More sharing options...
Chimera101 Posted September 16, 2011 Author Share Posted September 16, 2011 Good point I should have really said what bike it is. Its a K5 650 Bandit. No fairing so thats a bit of hassle I wont have, dunno about the radiator tho might have to remove it. Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted September 16, 2011 Share Posted September 16, 2011 you mgiht be able to just unbolt it from the frame and move it out of the way i would say that it is also best to use a wire brush on the bolts where it goes into the cylinder head and spray up witha good quality penetrating oil a couple of times before trying to undo the nuts or bolts whichever you have.you dont need to remove tank or drain engine oil if you can just unbolt the oil cooler and move it away enough.just remember to use new gaskets in the head where the pipes go in when fitting the new system Quote Link to comment Share on other sites More sharing options...
Chimera101 Posted September 16, 2011 Author Share Posted September 16, 2011 Awsome I will have a look when I get home and see whats what, Glad I dont have to remove tank or drain oil as I just changed the oil yesterday. Thanks for the info. Quote Link to comment Share on other sites More sharing options...
Jonabonospen Posted September 18, 2011 Share Posted September 18, 2011 ........ i would say that it is also best to use a wire brush on the bolts where it goes into the cylinder head and spray up witha good quality penetrating oil a couple of times before trying to undo the nuts or bolts whichever you have Very good advice as nothing worse than coming to do the job and finding you cant get the bolts undone and you then have to spray them up and wait a day or so. Plan in advance to save the pain on the day hopefully. Quote Link to comment Share on other sites More sharing options...
Chimera101 Posted September 19, 2011 Author Share Posted September 19, 2011 Cheers for the advice, I'll start putting a little spray onto the bolts over the next few days. I ordered the parts but it's up to 28days for delivery so I have abit of time to work at it.thanks again Quote Link to comment Share on other sites More sharing options...
Chimera101 Posted September 22, 2011 Author Share Posted September 22, 2011 Hi again, I recieved the parts for my exhaust a few days ago, and managed to remove the downpiped lastnite just before i't got too dark to do further work. I ordered a gasket for the link between the downpipes and the link pipe but discovered that ther is no way any gasket is gona fit in there. There is almost no gap between them, so I reckon im gona have to use an exhaust sealant.Any suggestions as to what type I should use or should avoid?thanks Quote Link to comment Share on other sites More sharing options...
argentum40 Posted September 22, 2011 Share Posted September 22, 2011 Well i had a leak where the Can meets the downpipes and i used Holts Firegum... a few dollops spread around the joint, wang the pipe on, tighten up and started engine... no leaks and jobs a goodun... you can remove any excess straight away before it hardens with a damp cloth or sponge... Quote Link to comment Share on other sites More sharing options...
Chimera101 Posted September 22, 2011 Author Share Posted September 22, 2011 Awsome, sounds like what I need so I'll have a look for that tonite.thanks Quote Link to comment Share on other sites More sharing options...
