Matt1974 Posted October 28, 2011 Posted October 28, 2011 Hi All,Does anyone know if the engine makes a certain noise when the valve clearances are buggered?cheers Quote
eastanglianbiker Posted October 28, 2011 Posted October 28, 2011 would depend if they had gone tighter or looser if the adjustment has loosened (increased) the gap there would be a slight tapping from the top end of the engine Quote
Tango Posted October 28, 2011 Posted October 28, 2011 Engines with shimmering & bucket adjustment are less likely 2 get negative valve clearances. So if the adjustment is out you'll get slight tapping from the top of the engine like EAB says. Quote
Boro Jake Posted October 28, 2011 Posted October 28, 2011 its a fazer mate they make all kinds of noises go buy how many miles its done. Quote
