Guest Posted January 31, 2012 Share Posted January 31, 2012 My bike drips out petrol but when you turn the petrol tap on it pours out help me ? Quote Link to comment Share on other sites More sharing options...
Nogin Posted January 31, 2012 Share Posted January 31, 2012 Check the pipe is not fubar, make sure it's connected ok, if that's ok then it's the tap or the tank.What bike? Quote Link to comment Share on other sites More sharing options...
mealexme Posted February 1, 2012 Share Posted February 1, 2012 could it be the drain bolt on the carbs? I don't pretend to know what I am talking about but I remember reading about a drain bolt on there, and from my understanding, the carbs are after the tap.check the pipes are all on correctly and see if you can track the leak because that will be a big help! Quote Link to comment Share on other sites More sharing options...
Roadtorque Posted February 1, 2012 Share Posted February 1, 2012 Do you want Matches or a Lighter Quote Link to comment Share on other sites More sharing options...
Fozzie Posted February 1, 2012 Share Posted February 1, 2012 Pours out of where exactly?My RS50 on a full tank dripped furiously out of the overflow after a ride as it seemed to shake it up a bit Need more info to really diagnose whats going on here Quote Link to comment Share on other sites More sharing options...
Comrade Posted February 1, 2012 Share Posted February 1, 2012 Welcome to the forum, nice introduction post! Quote Link to comment Share on other sites More sharing options...
Guest Posted February 1, 2012 Share Posted February 1, 2012 Thanks guys Quote Link to comment Share on other sites More sharing options...
TC Posted February 1, 2012 Share Posted February 1, 2012 Welcome to the forum, nice introduction post! If he's stood there with petrol pissing out everywhere about to blow himself up.How would like him to introduce himself.Hi my name is olly, sorry about the strong smell of fuel, but i have a slight problem that i am about to blow up. Then someone would ask him his location he would answer.Then he would be asked to pop into newbies to introduce himself.and be asked his location again Then told he has posted in 'bike chat' and it it really should be in 'Pitstop'then asked where he lives To then be told that i have no idea about the fuel leak, but someone will be along shortly that will be able to help you.Oh BTW Olly. Welcome to the forum. pop into newbies to introduce yourself Quote Link to comment Share on other sites More sharing options...
Nogin Posted February 1, 2012 Share Posted February 1, 2012 You wouldn't need to as his location as the lard ball of fire is likely to be reported by sky news! Quote Link to comment Share on other sites More sharing options...
Tango Posted February 1, 2012 Share Posted February 1, 2012 Hi Olly....welcome to the forum.... Could probably do with a bit more info on the make and model of the bike to help you more. If it has a carb it could be that the float has stuck......gently tap the float bowl with something that is not likely to cause a spark.... Blunt end of a screwdriver normally does this OK.If the fuel is leaking from around the tank it could be corrosion, seals gone in the tap, split in the fuel lines, fuel line fallen off....etc.So have a look around and see if you can pinpoint where the fuel is coming from....and get back to us.... Quote Link to comment Share on other sites More sharing options...
Comrade Posted February 1, 2012 Share Posted February 1, 2012 Dont think id be busy creating a post next to tank leaking petrol, i would be checking fuel lines or draining the tank of as much petrol as i could. Quote Link to comment Share on other sites More sharing options...
Susieque Posted February 1, 2012 Share Posted February 1, 2012 Moved to Pitstop! Quote Link to comment Share on other sites More sharing options...
Roadtorque Posted February 2, 2012 Share Posted February 2, 2012 Moved to Pitstop! Don't you mean Stoppit Sue Quote Link to comment Share on other sites More sharing options...
Ingah Posted February 2, 2012 Share Posted February 2, 2012 Hi Olly....welcome to the forum.... Could probably do with a bit more info on the make and model of the bike to help you more. If it has a carb it could be that the float has stuck......gently tap the float bowl with something that is not likely to cause a spark.... Blunt end of a screwdriver normally does this OK.If the fuel is leaking from around the tank it could be corrosion, seals gone in the tap, split in the fuel lines, fuel line fallen off....etc.So have a look around and see if you can pinpoint where the fuel is coming from....and get back to us.... This.The probability is that the OP means from his overflow pipe under his bike in which case it will be a stuck float / crap in the float bowls - if the above hit it with a blunt object tip doesn't work they need taking apart and the float needle needs to be removed and re-seated after all the crap around it is cleaned out. Quote Link to comment Share on other sites More sharing options...
