shakeyshane Posted February 7, 2012 Share Posted February 7, 2012 Just got my bike back.its had new plug tank air blasted out carb cleaned ect.wen its idle the rpm is 1000 or under and it dont sound right wen ticking over. Rides fine until i get it into 1st and try and pull away again it cuts out or bogs down isnt the rpm ment to be 2000 idle Quote Link to comment Share on other sites More sharing options...
Tango Posted February 7, 2012 Share Posted February 7, 2012 I don't know for sure....but I think 2000rpm idle would be a bit high for this bike. 1000 - 1200 I would have thought. Remember...this bike won't develop a lot of power low down.....so (in true 2-stroke style) you've gotta rev it to get it to shift..... Quote Link to comment Share on other sites More sharing options...
shakeyshane Posted February 7, 2012 Author Share Posted February 7, 2012 I don't know for sure....but I think 2000rpm idle would be a bit high for this bike. 1000 - 1200 I would have thought. Remember...this bike won't develop a lot of power low down.....so (in true 2-stroke style) you've gotta rev it to get it to shift..... Ok thanks mate ill give it ago.when its idle it also cuts out tho. Quote Link to comment Share on other sites More sharing options...
Tango Posted February 7, 2012 Share Posted February 7, 2012 You've gotta warm it up good and proper in this weather before taking the choke off......but if it's still doing it when warm then maybe lift the tickover up a bit..... Quote Link to comment Share on other sites More sharing options...
shakeyshane Posted February 7, 2012 Author Share Posted February 7, 2012 You've gotta warm it up good and proper in this weather before taking the choke off......but if it's still doing it when warm then maybe lift the tickover up a bit..... Pk ill try again tommorow thanks again Quote Link to comment Share on other sites More sharing options...
Susieque Posted February 8, 2012 Share Posted February 8, 2012 Yes, I'm with Tango - if I try & open the throttle on my bike before it is fully warmed up it will cut out! Quote Link to comment Share on other sites More sharing options...
Colin the Bear Posted February 8, 2012 Share Posted February 8, 2012 Called flooding. Cylinder is cold, If too much fuel air mix enters it condenses and wets the plug inhibiting the spark, so no bang and engine stops. Setting off on a small 2stroke is a bit of an art. Increase revs, let clutch bite, but not fully in, slip clutch keeping revs up with throttle. Let clutch in when moving. Practice makes perfect. Hope you don't live in a smokeless zone Quote Link to comment Share on other sites More sharing options...
