roy1962 Posted February 18, 2012 Share Posted February 18, 2012 Hello i have a problem with bar end weight,i have undone screw ,and now cant get it to screw back in,any ideas please.thanks Quote Link to comment Share on other sites More sharing options...
cb350sg Posted February 19, 2012 Share Posted February 19, 2012 in what way wont it go back in?Will it go like half way in then sort of seize up and not turn any more?maybe spray some wd40 in or retap it if the threads really are mangled Quote Link to comment Share on other sites More sharing options...
mealexme Posted February 19, 2012 Share Posted February 19, 2012 to get the bar end out (with mine at least) you undo the bolt which goes through the bar end, and then through a bit of rubber and into a nut. To put it back on, put it all together and put the nut on and tighten slightly before putting back in the bar. Then once it is in tighten it up more until you have a snug fit Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted February 19, 2012 Share Posted February 19, 2012 it sounds like you have undone the screw completly and released the nut held by the rubber in the handlebar if you cant get the rubber and the nut out it might mean that you will have to push the rubber right into the handlebar and then fit new bar ends Quote Link to comment Share on other sites More sharing options...
roy1962 Posted February 19, 2012 Author Share Posted February 19, 2012 thanks for everyone that helped.problem sorted now.the nut and rubber had came off and gone into handlebars,just got some new bar ends only cost £10 and better and lighter than the old ones .brilliant Quote Link to comment Share on other sites More sharing options...
roy1962 Posted February 19, 2012 Author Share Posted February 19, 2012 it sounds like you have undone the screw completly and released the nut held by the rubber in the handlebar if you cant get the rubber and the nut out it might mean that you will have to push the rubber right into the handlebar and then fit new bar endsthanks mate .you was right .got some new ones.got the old one out as well.but the ones i got was smaller and lighter,and better,thanks Quote Link to comment Share on other sites More sharing options...
Tango Posted February 19, 2012 Share Posted February 19, 2012 Lighter bar end weights could cause you more vibration through the bars....... Quote Link to comment Share on other sites More sharing options...
roy1962 Posted February 19, 2012 Author Share Posted February 19, 2012 Lighter bar end weights could cause you more vibration through the bars....... thanks . i didnt know that.they seemed ok today.ill keep that in mind.,still got the old ones ,original ones. Quote Link to comment Share on other sites More sharing options...
