Guest Posted April 17, 2012 Share Posted April 17, 2012 Am trying to get our old CLR125 Cityfly back on the road after its been parked up a whilePromblem there seems to be no electrics?New battery fitted but nothing No lights, horn or anything?Have checked small (3 way) fusebox and wondered if the bike has any other fuses (main fuse thing perhaps?) tucked awayANY help would be fantasticCheers Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted April 17, 2012 Share Posted April 17, 2012 i would check the wire heading up to the ign switch or the switch itself Quote Link to comment Share on other sites More sharing options...
Big Stu Posted April 17, 2012 Share Posted April 17, 2012 Trace the positive feed from the battery up to the ignition - most likely a corroded connector (speaking from personal experience ) Quote Link to comment Share on other sites More sharing options...
Colin the Bear Posted April 17, 2012 Share Posted April 17, 2012 New battery charged? Battery on right way round? Connections secure? Earth strap connected other end. Quote Link to comment Share on other sites More sharing options...
Fozzie Posted April 20, 2012 Share Posted April 20, 2012 If all else fails it's a CG in a different frock and the wiring loom will fit from one of those If theres too many damaged electrics just change out the whole lot. Quote Link to comment Share on other sites More sharing options...
