gsxr k3 suspension
fatboyzmc
Couple of places up north I know do a suspension setup depending on how you ride and how much you weigh etc.
Costs less than £100 for a setup using stock suspension. And obviously skys the limit if you go further!
Guest philgale
If your ever on a track day there is suspension setup there for about £45. They will give you track settings then change it for road afterwords so you get best of both
The owners manual shows how to set it harder or softer. I would suggest you set your sag first based on your weight and once your preload is right you can then look at the damping and compression rates to suit your riding style. Google setting sag if your unsure.
