Lads my rear shock is knackered and needs replacing... It has gone very soft so have any of you Bandit owners past/present replaced the rear shock from another bike?.... If so what other ones can i use and was it a straight swap or did it need mods?
One of the Gixxer shocks will fit. Check dimensions of yours and compare with Gixxer shox on Gixxer junkies or a shock site.
I bought a second hand Hagon for my B12 and it gobbed it's oil onto the rear tyre!!!! A Busa shock may fit too ? :mrgreen:
There are some sites with a lot of information on this, they come with dimensions so you want to find which ones fits and then which one you think suits your needs :)
My bike currently runs a CBR1000RR shock. Its to fit a RR swingarm but I have found it to be very good, firms up the rear and stops it fishing when braking hard. But thats tailored to my needs and I like to ride everywhere at the quickest possible speed allowed :mrgreen:
It lined up perfectly, the size of it was tight and I did have to file down one end of the supports as it was too long but we're talking minor stuff. The holes lined up and didnt even require spacers!
I will add I just fitted a GSXR600 shock to a K4 SV650 so Suzukis definately seem to interchange their part sizes!
they interchange a lot of their parts too. Ever noticed how the bandit and SV have the same indicators? all to do with keeping costs low, which is good for me because I dont have to ook for bandit specific stuff :)
Just work off lengths as many different manufacturers will do the right length shock!
Then look at where its from, so if its sports it will be firm and I would suppose a street/sports tourer setup is what you want though if its adjustable that wont matter too much :)
Yes on the length, but think about different strokes, a similar shock, that is meant to move half as far due to being geared (cam/link whatever) differently, will be twice as hard as a shock off a similar use bike and vice versa.
SO if you get a shock off a bike that has a real hard rear set up, but put the shock on a bike that has half as much travel, it will be soft on that bike.
Make sense?
Indeed, I encountered this fitting the Gixxer shock onto the SV. Took some fiddling :)
Shock travel needs to be similar though a similar length shock from a similarly set up bike will likely be ok.
However checking is always good, I had some fun fitting a Ninja shock to an old shape SV because of this :lol:
Make sense?
:stupid:
you need to think of spring rates and things like that other wise you could be in a worse position once you fit a different shock
If you can afford it fit a hagon they dont cost too much and are pretty good for the road :)
  • 3 months later...
I managed to get a very good shock off a B12 with hyperpro spring and it slotted straight in... i may need to adjust the preload abit though but i will get it checked first.. i knwo bugger all about setting shocks up :lol:
