Suzuki Intruder VL 125 - Circuit problems with lights..
Hi there,
In the last couple of weeks I discovered on the way to work that on using any lights on my bike, it cuts the engine. I've charged the battery and got her started again but there is something wrong with the circuit with the lights and I'm in need of a little advice. Anyone else had similar problems?
hi and welcome to the forum you need to check charging system and current being passed through battery when engine on tickover then when revving slightly and then again with lights on as it sound like the alternator might not be charging properly and is relying solely on battery power
as above
first check the voltage of the battery with the bike off
then start it and check it again with lights off
post the results :)
Thanks for the advice, I will have a look at it in the morning and post my findings, cheers
