i bought a new battery 6 months ago and havent used the bike much since buying it. i started using it again a few weeks ago and first day had to bump it. i then rode it 150 kms, straight. i hoped this would charge the battery but it seems to stay charged for about 5 mins... so i suppose it would be better to change it? im getting a bit sick of bumping it twice a day for work.
anyway, i was wondering, is there anything i should know if i go to place a buy a brand new battery and fit it myself? will i need to charge it or do anything to it before using it or can you usually just put them straight in? thanks in advance
they should come already charged and ready to go
before you buy a new battery get a multimeter and test the charging system to make sure you are getting enough charge
I suspect you are as one the bike is running it keeps running
  • 2 weeks later...
I would highly recommend the CTEK charging system, if you shop around you can get them for as little as £35, though some places charge over £100!
It is capable of reviving batteries with very low charge and will maintain charge on a battery so you can leave it plugged in indefinitely.
A very good product, just make sure you get the correct voltage and ampage charger for your bike.
I agree, great product brought one a few weeks back all's well so far.
http://www.ebay.co.uk/itm/CTEK-Multi-MX ... 0744951544
