Well guys i did my MOD1 this morning and am sorry to say I failed. :cry: I completed everything almost perfect with the exception of the avoidance. First run I was 1kph too slow so was sent around for another go. This time 56kph but didn't swerve enough and clipped the cone! :x As you can imagine I am gutted, I have asked for another slot as soon as possible so will see how soon it is. :cry:
Bad luck mate........I'm just glad I did my test back in the days when it wasn't so complicated..... :wink:
Anyway....hope you get another slot soon and are successful next time...... 8-)
Better luck next time mate.
My instructor gave me a wee tip that found quite helpful for the avoidance.
If the avoidance causing you to swerve to the right either tuck your feet under the gear changer or put your foot right back up on the foot peg as soon as you get into 2nd gear so its all out the way before even going into the bend leading up to the swerve.
Same for the avoidance if its to the left.
Maybe worth a wee try
He said the amount of people the fail mod 1 for clipping the cone on the avoidance is high.
Best of luck next time mate
Thanks guys and thanks for the tip Dynamo. I am praying I get it right next time as it is something I can't practice.
