Robik Posted July 3, 2013 Share Posted July 3, 2013 Seems I do indeed have a leaking radiator, the leak seems to be coming from the top of the radiator, but not from any of the hoses or connectors.My car engine fix would be to put some radweld in, but it seems that is the not advised for bike engines, is this correct?I might have to replace the radiator, with new of 2nd hand rad (if I can find a fully pressure and temperature tested one that is). Quote Link to comment Share on other sites More sharing options...
megawatt Posted July 3, 2013 Share Posted July 3, 2013 I used Kseal It and have had no further problems. Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted July 3, 2013 Share Posted July 3, 2013 they dont recomend it for bikes as the water ways inside the engine and the veins of the rads are that much smaller,if you can see where it is leaking from you might be bale to solder or get it brazed up if you can find a good replacement Quote Link to comment Share on other sites More sharing options...
Robik Posted July 3, 2013 Author Share Posted July 3, 2013 If I can find the leak, I wonder if something like this J-B weld would seal it up from the outside of the radiator.http://en.wikipedia.org/wiki/J-B_Weld Quote Link to comment Share on other sites More sharing options...
Robik Posted July 3, 2013 Author Share Posted July 3, 2013 I used Kseal It and have had no further problems. Just seen advice against this sort of product for bike engines. Concerned that I might cause a bigger problem with the engine. That's great that it worked ok for you though! Quote Link to comment Share on other sites More sharing options...
megawatt Posted July 3, 2013 Share Posted July 3, 2013 Like I said, I used it on a Fireblade system and have had no further problems. Please yerself if you don't believe me, just don't expect any more informed advice from someone that has been working on bikes for 37 years . Quote Link to comment Share on other sites More sharing options...
Robik Posted July 3, 2013 Author Share Posted July 3, 2013 I appreciate the advice megawatt, sorry it seems that I may have touched you in places you don't like to be touched and for that I apolgise. I do believe you (why would you lie?). Just looking at all my options that's all. Quote Link to comment Share on other sites More sharing options...
Tango Posted July 4, 2013 Share Posted July 4, 2013 I used k-seal on my speed 4........worked a treat. It remains liquid until it gets hot and comes into contact with air....ie, through a hole in a rad. But if your leak is that big it may be the rad has split......so may need a new core......or a new rad. Quote Link to comment Share on other sites More sharing options...
megawatt Posted July 4, 2013 Share Posted July 4, 2013 Thanks Bob. No offence taken mate, but give us some idea of the leak rate/size of the hole and if not too big, at least try KSeal it. It's not thick and gloopy like Radweld.Costs about £10 a half litre and you get about 3 systems worth when mixed with water. If it doesn't work, then spend a lot more on a repair or a new rad? Quote Link to comment Share on other sites More sharing options...
Robik Posted July 4, 2013 Author Share Posted July 4, 2013 Hi,Thanks Tango and Megawatt, I can find this stuff easily on the net, but that means having to wait until next week to use it. In my quick search I can't seem to find it in Halfords, not sure who else might stock it? Quote Link to comment Share on other sites More sharing options...
Robik Posted July 4, 2013 Author Share Posted July 4, 2013 I found out my local spares places places sells it (236ml) bottle for £10, this seems to be the only size they sell on the net too. Your 0.5l find for £10 was a good find megawatt!For my cbr 125 how much would you suggest I put in?Thanks! Quote Link to comment Share on other sites More sharing options...
mealexme Posted July 4, 2013 Share Posted July 4, 2013 It seems that I may have touched you in places you don't like to be touched http://www.tshirthell.com/shirts/products/a324/a324.gif?v11301bss2I'm sorry, I had to. I have no useful information to add to this post, so I shall go away now Quote Link to comment Share on other sites More sharing options...
Robik Posted July 4, 2013 Author Share Posted July 4, 2013 Quote Link to comment Share on other sites More sharing options...
megawatt Posted July 4, 2013 Share Posted July 4, 2013 Check on container, think it's a 2 or 3 to 1 mix. I used hot water in a 2 litre pop bottle. Fill your cooling system up with tap water and drain into a measuring container(pop bottle) or check a workshop manual. I had loads left. Quote Link to comment Share on other sites More sharing options...
Robik Posted July 4, 2013 Author Share Posted July 4, 2013 Thanks megawatt,Do you mean 2/3 water to 1 K-seal mix? I couldn't find any figures on this to confirm.I found this from http://www.kseal.com/wp-content/uploads ... l-2013.pdf"Shake the bottle vigorously for 30 seconds and add the entire contents to the radiator or header/expansion tank. If adding to the radiator do not pour directly onto the radiator core. (For very small cooling systems e.g. motorbikes, it is possible to add just part of the bottle but you must make sure that the contents are extremely well mixed first."Would recommend flushing out the cooling fluid after the K-seal has done it's job or just leave it in with the current fluid thats already in there?edit: found this information too from http://www.kseal.com/faqs/"How much K-Seal do I need?1 standard bottle of K-Seal (236ml/8floz) will treat cooling systems with a capacity up to 20 litres (this covers motorbikes up to light commercial vehicles). For larger cooling systems use our Heavy Duty (472ml/16floz) size K-Seal."You had the Heavy-Duty bottle 472ml Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted July 4, 2013 Share Posted July 4, 2013 i would say you need to find out how much coolant your system holds then divide the kseal to find out how much of the botle you need as your cooling system is likely to only be 1 or 2 litres not the 20 the full bottle will work with Quote Link to comment Share on other sites More sharing options...
Robik Posted July 4, 2013 Author Share Posted July 4, 2013 i would say you need to find out how much coolant your system holds then divide the kseal to find out how much of the botle you need as your cooling system is likely to only be 1 or 2 litres not the 20 the full bottle will work with Thanks. According to the cbr125 bike manual. Cooling system capacity is 0.70L (Radiator and engine) and 0.28L (reserve tank), so just under 1L. So does this mean use only 1/20th of the K-Seal bottle? Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted July 4, 2013 Share Posted July 4, 2013 in theory yes but hopefully mega will be along soon who has used it to see how he worked out the figures on the amounts used,but yes in threory you would use 1/20th of the bottle Quote Link to comment Share on other sites More sharing options...
Robik Posted July 4, 2013 Author Share Posted July 4, 2013 That makes "theoretical" sense thanks eastanglianbiker. Looking forward to mega's thoughts on this hypothesis Quote Link to comment Share on other sites More sharing options...
acting_strange Posted July 4, 2013 Share Posted July 4, 2013 OK so 20 ltrs = 700floz (35floz to 1 Ltr)Your bottle = 8floz700/8 = 87.587.5/8 = 11 therefore the correct dillution is 1:11 Fluid/WaterYour bike holds .7 ltr fluid and .7 ltr = 24 fluid ozAt this rate you would be better off mixing 1ltr of antifreeze solution and add 1/3 (85ml) to that then pour that into your machine and run it up. Keep whats left to top it up because you will surely need to. Quote Link to comment Share on other sites More sharing options...
Tango Posted July 4, 2013 Share Posted July 4, 2013 I used about 1/3rd of the smaller bottle in my Speed 4.......with no ill effects...... Quote Link to comment Share on other sites More sharing options...
Tango Posted July 4, 2013 Share Posted July 4, 2013 Oh......and you leave it in the system as it will continue to seal any other leaks if they occur......you don't need to drain and refill the system..... And.....I tend to use distilled water in the cooling system on my bikes.......stops the waterways furring up with limescale....... Quote Link to comment Share on other sites More sharing options...
Joeman Posted July 4, 2013 Share Posted July 4, 2013 In the old days, they used to use egg white to seal up leaks.Just crack an egg and pour in the egg white Quote Link to comment Share on other sites More sharing options...
Robik Posted July 4, 2013 Author Share Posted July 4, 2013 Oh......and you leave it in the system as it will continue to seal any other leaks if they occur......you don't need to drain and refill the system..... And.....I tend to use distilled water in the cooling system on my bikes.......stops the waterways furring up with limescale....... Do you mean distilled water to flush out the cooling system or distilled water instead of antifreeze coolant?Ok, so I am not sure when the last time the coolant was replaced in the bike (the bike is 6 years old, done about 9.5k miles). Not sure if it is a good idea to replace it with fresh coolant mixed with about a.... umm let me refer back to acting_strange's post... At this rate you would be better off mixing 1ltr of antifreeze solution and add 1/3 (85ml) to that then pour that into your machine and run it up. Keep whats left to top it up because you will surely need to. Sorry if I misunderstand this, but would this not mean that I end up putting too much coolant/k-seal mixture in the system? Quote Link to comment Share on other sites More sharing options...
Tango Posted July 4, 2013 Share Posted July 4, 2013 Distilled water and antifreeze in the correct ratio........if you use tap water it can fur up the waterways in the engine.....much like your kettle furs up.......and don't forget that antifreeze also helps the cooling system......so it keeps the bike cooler in summer too...... Quote Link to comment Share on other sites More sharing options...
