Guest Posted July 27, 2013 Share Posted July 27, 2013 Hi, can anybody help? trying to find out where the vacuum line that goes to fuel petcock is suppose to attach to.trying to fix friends bike, vacuum line is missing. its a 96 vulcan 800 california model, I assume that line turns on the petcock in on and reserve position?manual does not show vacuum routings.Thanx for any help!dave Quote Link to comment Share on other sites More sharing options...
Tango Posted July 27, 2013 Share Posted July 27, 2013 Dunno if this is any help mate.......or you may just have to call them for advice...... I think it may be part number 92191A.......but that really is a guess..... http://www.kawasakioriginalparts.com/ka ... 1996&ca=CA Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted July 27, 2013 Share Posted July 27, 2013 you will normally have 2 or 3 pipe outlets on the petcock,if it has 2 the then smaller one is normally the vacuum,if it has 3 the one is normally for main tank one for reseerve and once again smaller one for vacumm pipe,if you are unsure you can fit a piece of hose to one of the pipes and suck gently on it,if petrol flows out of the other one then you have found the vacuum pipe Quote Link to comment Share on other sites More sharing options...
