Benn Posted September 25, 2013 Share Posted September 25, 2013 It feels like my front fork has gone soft and compresses way to much. There's no oil leak around the fork seals or anything though...How do I know if this is just my imagination or not? Thanks Quote Link to comment Share on other sites More sharing options...
bex Posted September 26, 2013 Share Posted September 26, 2013 this is a possibility, the oil degrades and becomes thinner through use and therefore has less resistance.your manual should give you guidelines but tbh its not much of a job to change it so just get some new oil. if that doesnt help then look at your compression/rebound settings Quote Link to comment Share on other sites More sharing options...
Fozzie Posted September 27, 2013 Share Posted September 27, 2013 Is the bike high mileage? As springs do wear out!My old yellow cbr was very bouncey at 40k miles!To put off the wear, replace oil, get the bikes front wheel off, do one fork at a time. Take off the fork, carefully remove the top and dump out the oil. Pump it out using the cartridge and then replace the oil. Use a metal ruler to set the air gap to make sure the level is right. Quote Link to comment Share on other sites More sharing options...
Benn Posted September 28, 2013 Author Share Posted September 28, 2013 Only 11,500... I guess I can be hard on the old gal, but nothing too extreme. I'll look into replacing the oil and try and get it done soon. Thanks for your help guys Quote Link to comment Share on other sites More sharing options...
Fozzie Posted October 2, 2013 Share Posted October 2, 2013 Just remember fella, if the springs are fine and you put heavier oil in there, you can damage the handling!They are small light springs in 125s so its possible! I'd get the springs out and check to see if there is any wear. Quote Link to comment Share on other sites More sharing options...
Tango Posted October 2, 2013 Share Posted October 2, 2013 Lay off the pies!!..... Quote Link to comment Share on other sites More sharing options...
